mini e-revo problem
mini e-revo problem
ok i have the 1/16 mini e-revo that is brushless and im running two 11.1v 1300mah li-power lipos and it would just instantly flip over on its back when you gave it throttle. last week the servo went bad so i replaced it and now with both lipos at full charge it has hardly any power. any sugestions?
Are you running 2, 3s in series? That would mean you killed your esc and/or motor. Did you buy a smaller pinion other than the one supplied by Traxxas? If no then you could have overheated your stuff and killed it.
Now for the less scary stuff. lol
Try to recaliborate your ESC maybe. Are your TX batties fully charged? If it happined as soon as you switch servos maybe its there. Bad servo, maybe pluged in wrong.
Super Moderator
Trader Rating: 31 (100%+)
Just like the other guy, you need to be over here...
http://www.rctech.net/forum/micro-mini-scales-115/
