slash tires?
Old 05-13-2011, 11:12 AM
Suspended
Default slash tires?
i have the 1/16th slash and was wondering if somone can post a link for a wheel and tire combo for hard packed dirt, a green compound, soft tire is what i need, like the bar codes i use on my 1/10th scale 4x4 slash. my 1/16th slash has the 12mm hex hub. thankyou
rcman45 is offline
Old 05-15-2011, 01:21 PM
Suspended
anyone there????
rcman45 is offline
Old 05-16-2011, 07:10 PM
jdob's Avatar
There is nothing out there other than the stock Traxxas wheels/tires for the 1/16th Slash. You can search your butt off and still come up empty - You can put 1/10th touring car wheels/tires on it, but they are a little on the big side, or you can try and find some older left over wheels/tires for the Kyosho Mini-Inferno, but they are a little on the small side. I think you can still find some of the wheels/tires for the Mini-Inferno from the The Toyz on-line store. If I remember right - if you can find some of these you will also need the hex adapter from the Mini-Inferno to fit the wheels because it is smaller than that of the stock mini Slash. Hope this helps...
I contacted Pro-Line to see if there were any chance of even just one set of wheels/tires for the 1/16th Slash being released - they said - if there is a demand they would do it...I guess there just isn't a demand at this time...
jdob is offline
Old 05-16-2011, 07:13 PM
jdob's Avatar
Double post...
jdob is offline
Old 05-17-2011, 10:49 PM
Smile hay
I have a frog doing nothing. But looking. For a home
havenfun is offline
