BIG PROBLEM!!! MERV
BIG PROBLEM!!! MERV
i got the outer race of the bigger bearing STUCK IN MY rear HR aluminum knuckle..
I was replacing all my bearing in my merv but this one was really bad so i smash it with a hummer. half part cames out but the outer race got stuck in there
How do i get it off?
ps: does any have 1 rear HR aluminum laying around that could sell cheap to me? Im from portugal btw, got paypal ready.
Thank you
[IMG]
Thank you
[IMG]
yee, i think i'm gonna do that.. i dremel is not that expensive and i'm sure i'll need for some other things in the future.
Yeah, dremels are infinitely useful, r/c or not. Again, I just want to point out, I've never tried what I described, but it should do the trick. Remove some of the race just by making a cut through it, and the ring should be able to shrink and slip right out. (I hope I'm explaining this well enough that you understand what I mean) I know how small those knuckles are, so I don't imagine anything else really fitting in there to cut it besides a dremel.
ye i got your point. thank you very much.. i'm off to shop
YES, PROBLEM SOLVE !! THANK YOU GUYS
I DID DREMEL IT
I DID DREMEL IT
Part of the problem is the hubs are machined before they are annodized and that annodized coating adds thickness so bearings are a tight fit , take off the annodizing and I bet the bearings come out easy .
Or get some nice GH knuckles instead of the Chinese stuff.......
