Micro setup station solutions?
An RPM camber gauge will work for setting camber (just make sure your wheels arent tweaked), and if you know you toe links are the same length l/r, a little bit of trig can tell you what your toe is
what does that link bring you to?????????
The RPM camber gauge is very precise. It reads exactly the same as my hudy gauges on my 1/10. You just have to watch for tweaked wheels that can skew the reading.. it may be worth it just to have a set of "set up" wheels. For calculating toe, assuming the reading is taken correctly you shouldnt be off more than a tenth or 2, which is about as much precision as you have with any setup station.
Like this?
It is made by a friend and did use some of these:
