2 Attachment(s)
HERE IS THE NEW BODY
i love this thing what scale is this bad girl
Originally Posted by rustlererad3
(Post 11602227)
Car looks sick bro. Cant wait to give it a run:cool:
I want to have one of these
Part i like most is a double wishbone front end on such a tiny car. This car a 10 steps ahead of everything else i have seen. That is one advanced little car. Kudos Marvet.
1 Attachment(s)
We have 8 Rhinos in stock.
News!
We will be adding a build option for the rhino an extra $12.50 receive a built kit. Tell us which spur gear you want, 47, 49 or 51.
ORDERING FROM WEBSITE
WHEN ORDERING FROM WEBSITE AND USING PAYPAL, IF YOUR SHIPPING IS UNCONFIRMED BY PAYPAL, THE BUYER WILL GET AN EMAIL FROM US ASKING FOR YOUR SHIPPING ADDRESS, ADDRESS MUST MATCH PAYPAL INFORMATION. I WILL EMAIL YOU , IF YOU DO NOT REPLY WE WILL CANCEL YOUR ORDER AND YOU WILL NOT BE ALLOWED TO ORDER FROM US. EVER!
THANK YOU. |
are elctronics, body and tires the only thing needed to complete the kit?
limited edition? are you only making so many of them and stopping? what electronics do you recommend? |
Originally Posted by strodedawg
(Post 12034788)
limited edition? are you only making so many of them and stopping? what electronics do you recommend? castle creation, reedy and novak make systems that will fit our cars. if you use castle you must find early motors because the new 4 pole motors are to long. |
Just found out about this killer little machine! Good to see someone still working on the 1/18th platform
1 Attachment(s)
We are going to produce 10 oval rhino kits.
Please help with diff problem....
When I tighten the right wheel onto the hub via the threaded axle...the right diff also tightens and eventually locks causing the car to pull right with any torque applied. Is the solution to not tighten the wheel to the hub and ensure its really loose? Edit: Even with a loose wheel nut, it still pulling right on acceleration. Uneven diff? If I over tighten the diff and it still pulls, does that rule out the diff causing the pull? |
| All times are GMT -7. It is currently 01:32 AM. |
