-   -   RC18T Battery Compartment Dimension (https://www.rctech.net/forum/micro-mini-scales/434778-rc18t-battery-compartment-dimension.html)
BoBlitz 09-14-2010 01:30 PM
I have searched high and low and i cannot find where anyone has posted the actual dimensions of the battery compartment. i have seen many posts mentioning which batteries will fit, but i am looking for the actual dimensions. Unfortunately i cannot measure the car myself as i dont have it yet.
Any help would be great.
Thanks,
Bermbuster 09-14-2010 02:17 PM
Thanks,
1.260" x 4.100" x .718" this height is adjustable you can go higher
or
32mm x 104mm x 18mm this height is adjustable you can go higher
the height can probably go to 25mm or more if needed....
AmmoJammo 09-14-2010 02:21 PM
you can also put the battery on its side, and modify the chassis to use velcro straps instead of the stock battery clamp, so you can fit larger batteries such as these.
http://www.hobbycity.com/hobbycity/s...idProduct=9937
http://www.hobbycity.com/hobbycity/s...idProduct=8932
as can be seen in my RC18t thread.
http://www.rctech.net/forum/micro-mi...new-tyres.html
BoBlitz 09-15-2010 08:45 AM
Thank you
el_Fernando 09-15-2010 10:02 AM
I'm guessing that the RC18b2/t2 is the same exact dimensions?
Driver86 09-15-2010 11:03 AM
Good question. The drive system is completely different so I wouldn't take it for granted.
edit:
I looked at a picture and they seem to be the same tub, the only difference being a cut out in the rear before the transmission for the extra gear for the belt system.
AmmoJammo 09-15-2010 12:07 PM
I just had a look at the RC18t2, and it seems horrible, how am I supposed to fit my motor and battery in it? :P and I hate belts!
burnineyes 09-15-2010 12:39 PM
The belt chassis is a totally different tub and will fit a slightly larger battery.
Ammo, what exactly was the problem? I know its not quite as easy to fit every possible motor in the belt drive, but I have no problem fitting anything meant for 18th scale in it.
Driver86 09-15-2010 01:25 PM
I agree. I too hate belts and people have been having issues with the tension on these. I think you'd be better off with a Duratrax, HPI, Kyosho or X-Ray. Even a Mini-T desert if you don't mind 2WD.
AmmoJammo 09-15-2010 02:23 PM
whats this 18th scale motor you speak of? See my rc18 thread for info on what i'm running.
burnineyes 09-15-2010 05:53 PM
Ahh, I see your motor looks pretty monstrous in your car. I was simply speaking about any 20x30-26x40 and several sizes in between that I have fitted to the belt chassis with no problems. But it looks like yours might be even bigger; have you considered a larger car?
AmmoJammo 09-15-2010 08:22 PM
its 28 x 48mm, if i had a bigger car i'd need a bigger motor :p
burnineyes 09-15-2010 09:14 PM
I should have known;)
AmmoJammo 09-15-2010 10:22 PM
should have known what? :P
