DuraTrax Vendetta SC Questions
#46
Ran both mine yesterday and the front diff went out on 1 after the first jump and the rear diff went on the other after 1 pack along with 1 universal. Is this a common problem? Do I need ball diffs and CVD's? Dam if that's the case we're talking close to $300 in upgrades for both little trucks. I paid $220 for both, lol
#47
Suspended
The track i race it at is very nice and well maintained.
I called Duratrax ( hobbico ) and explained my dis-appointment with them. They were very cool about it, and once I took pictures of the gear diff, and gave my invoice number from Tower Hobbies, they sent me out a set of ball diffs.
A set of them, for free. They arrived yesterday, i put them in and the whole truck just feels better.
The diffs have metal out drives and plastic gears.
#49
Metal ring and pinions are entirely un-necessary unless you are running a Neu or TRX motor and have a very heavy finger.
#51
I run a 10.5 brushless and 1800 lipo in mine with the plastic gear diff and the metal out drivers and have had no problems with it.
#52
I've had the same ring and pinion gears in my ST for the past 3 years coupled with a Goose 13.5 and have never, ever had to do anything to them other then rebuild the balls. If you build them properly, shim them properly and run them properly......there is absolutely no need for metal gears.
All I'm doing here is trying to get people to not spend money that they do not need to spend.
#53
Diesel is correct the main gear on the diffs are extremely strong. I have been running a Neu geared for about 40mph and it will wheelie at anything below 25mph. I have been running this for over a year with very little wear or damage. As long as they are kept with a little grease on the gears it will last and last.
#54
#56
I found that installing 1 shim behind one of the bevel gears in the diff tightens it up a bit and limits the diff action just a little while helping the gears to mesh tighter and take out some of the play that can be destroying them. Also filling them with grease will greatly help, as well. I have done this to 1 of my 2 trucks and can tell the difference with the grease.
On my diff output drive issue, I called DTX and they are taking care of both trucks. All I have to say is that their customer service is golden!!!
Now I wait for my HK 2200mah LiPos to arrive.......
#58
about 2.4" tall
