Losi stock esc/motor problem >
Old 08-11-2010, 10:23 AM
Default Losi stock esc/motor problem
I hooked 7.4 lipo to my mini slider and it ran great for about 10 mins then I lost throttle and the esc was blinking red/green/orange. It wasn't an overheat because I let it completely cool and now it'll run for 5 seconds and shut off again. I bolted another stock motor and it ran for 10 minutes and did the same. I've done this in the past with the same setup and had no problems. Did I fry the motors? Thanks!
danam404 is offline
Old 08-11-2010, 12:19 PM
Could it be lipo cut off? I don't really know the esc but it sure sounds like a low voltage shut off.
leppis is offline
Old 08-11-2010, 12:56 PM
I will throw a fresh pack in it and see if it runs. Is there anything inside the motor that I could have fried causing the esc to shut it down?
danam404 is offline
Old 08-12-2010, 07:58 AM
nope, fresh pack still runs for 5 secs and shuts off. Anyone else?
danam404 is offline
Old 05-07-2012, 06:42 AM
I know this is an old post but since I haven't seen anyone respond with some solution, thought of adding to this.. I have a slider too and recently it started showing the same symptoms described here. It has stock setup. Servo works fine and is as fast as it normally is so nothing wrong with the receiver. However, motor runs fine for about 5-8 seconds and then it shuts down. It's not overheating problem since everything is quite cool and I am running it in 50degree weather.
bashwithslash is offline
