Tire Options for 1/16 Mini Slash >
Old 09-10-2009, 05:25 PM
  #16
CCH1978's Avatar
Trader Rating: 27 (100%+)
any suggestions for one road wheel combos?
CCH1978 is offline
Old 09-10-2009, 05:51 PM
  #17
gashuffer's Avatar
Trader Rating: 48 (100%+)
Originally Posted by UpAllNightRCer
Yeh lets stick with listing only wheels/tires that we don't need to trim any of the truck body, I will say that if slight trimming/modding or tuning to fit is acceptable. (Slight trimming/modding would be classified as using sand paper with not a lot of pressure applied. Major trimming/modding would be using a tool of sorts to cut or reduce the truck body in some way).
I didn't mean cut out the whole wheel well Just trim what you need to give clearance. Your going to rub the top even with stock tires if your jumping or bashing off crazy sh!t...
gashuffer is offline
Old 09-10-2009, 05:53 PM
  #18
gashuffer's Avatar
Foams if your on a track, St on road tires for the street.
Old 09-10-2009, 06:05 PM
  #19
CCH1978's Avatar
ST onroad tires?
CCH1978 is offline
Old 09-10-2009, 06:11 PM
  #20
Travis Bickle's Avatar
I am running the Kyosho mini inferno wheels/tires (not the mini inferno ST, they are wider)They are the closest size to the stock wheels/tires in height and width, you need the mini inferno adapters to run them. Night and day difference in grip compared to the stockers.
Travis Bickle is offline
Old 09-10-2009, 06:37 PM
  #21
gashuffer's Avatar
ST onroad tires?
http://www3.towerhobbies.com/cgi-bin...&I=LXRXY3&P=ML
They will work with the ST wheels.
Old 09-11-2009, 06:58 AM
  #22
Dieselpower's Avatar
Trader Rating: 25 (100%+)
Vendetta ST wheels
Mini Quake onroad tires
stock DTX foams only in the rear
Stock foams samiched with HPI 24mm hard foams in front
Handles like a dream onroad.
Pretty much any 2" or 1.9" onraod tire will fit. The Mini Quake split block tires will also fit the ST rims and are a little more suited to low-bite tracks.
Attached Thumbnails Tire Options for 1/16 Mini Slash-100_0834.jpg   Tire Options for 1/16 Mini Slash-100_0839.jpg
Dieselpower is offline
Old 09-11-2009, 08:28 AM
  #23
CBHVR6's Avatar
Trader Rating: 19 (100%+)
i dont know if its been said because i didn't read the thread but traxxas pro star 2.2 wheels with proline badlands!
CBHVR6 is offline
Old 09-11-2009, 09:11 AM
  #24
A significant amount of tire/Wheels from HPI will work on the Mini Slash. The 10th scale road tires come in various compounds and they have a rally tire that has some deeper treads. I beleive they are all 12mm hex so no adapters needed. Check out the HPI Racing website
http://www.hpiracing.com/hpitires/touring/
I also understand that Tamiya has some tires that will work too. I am very interested in soft road tires for carpet.
stockslasher is offline
Old 09-11-2009, 11:57 AM
  #25
gashuffer's Avatar
That is just plain silly.
Old 09-11-2009, 12:21 PM
  #26
CBHVR6's Avatar
haha yeah. it seemed like a good idea. It was fast if you feathered the throttle and it would do backflip after backflip but as far as over all drive ability it just wasn't there.
CBHVR6 is offline
Old 09-11-2009, 12:53 PM
  #27
JatoTheRipper's Avatar
Those will NOT fit a Slash...
JatoTheRipper is offline
Old 09-11-2009, 12:56 PM
  #28
gashuffer's Avatar
What gearing are you using with those tires?
Old 09-11-2009, 01:15 PM
  #29
Hmm wish you did read the thread, since you would know this thread is only for 1/16 slash and I'm assuming from your pic that you are discussing putting those tires/wheels on a e-revo. Please only post about the 1/16 slash, there are plenty of threads e-revo's so post there.
UpAllNightRCer is offline
Old 09-11-2009, 02:22 PM
  #30
CBHVR6's Avatar
the slash has smaller hubs? i thought they were both the same.
CBHVR6 is offline
