clicking nosie on my 18r >
Old 04-01-2009, 08:37 PM
mark.t's Avatar
Default clicking nosie on my 18r
i have a 18r and when i was driving it some thing in the back (around the motor and diff) there is a really bad clicking nosie.
what could it be
and also i am having a hard time getting it to track stright what can i do i adjust the trim but it never seems right.
thanks for the help
mark.t
mark.t is offline
Old 04-01-2009, 09:17 PM
myrxseven's Avatar
what could it be
thanks for the help
mark.t
Clicking noise is most likely debree caught in the spur gear or the pinion gear. Just pop it out with your fingernail or a tweezers. As for the tracking streight, pretty much not gonna happen with the stock setup. I recommend some ajustable turnbucles, and give it a couple degrees of toe out. That will allow it to track streight.
Good Luck
myrxseven is offline
Old 04-02-2009, 03:15 PM
RC Dad's Avatar
Trader Rating: 26 (100%+)
the clicking noise is most likely the dogbones if you lost the springs in the outdrives. We fought this for 2 race days until I discovered that the foam chip I used to replace the spring had packed into the outdrive.
The dogbone rides inward and ticks as is tries to slip in the hub, If you lost the springs, you can use the front suspension springs off a 1/12 scale pan car, get the lightest ones you can find .
RC Dad is offline
Old 04-02-2009, 04:54 PM
mark.t's Avatar
cool i'll check that out thanks for all the help.
mark.t
mark.t is offline
Old 04-02-2009, 07:05 PM
mark.t
if all else fails, try the tranny
paintsplat20 is offline
Old 04-04-2009, 09:44 AM
mark.t's Avatar
okay getleman i need some help with building shocks. the shocks i am buildng are the threaded aluminum front pair.
some problems i am having are i cant seem to get hm rebound the same from left to right.
second the shocks piston rods(not sure if that is there real name) but when i put them together i have to tighten down the adjusterto the point it almost falls off. how do i shorten them?
any help would be great
thanks mark.t
mark.t is offline
Old 04-04-2009, 11:10 AM
Suspended
There is no "tranny" in any of the RC18's.
Lightin' is offline
Old 04-04-2009, 11:13 AM
Suspended
thanks mark.t
Not quite sure what you are asking, but it sort of sounds like you didn't get the rebound matched between the pair when you rebuilt and bled the shocks. They need to match. Otherwise I don't think you want to "shorten" them, but instead make sure they are filled and bled adequately.
Lightin' is offline
Old 04-06-2009, 08:30 AM
mark.t's Avatar
thanks for the shoc help i got them a bit closer to exact thanks,
well now i am ready for my motor setup i want sme thing that i can handle but go fast at the same time so i can compet at races the two i lookedat are the castle creations micro pro. and then the team tekin. wich should i get thanks for the help.
mark.t
mark.t is offline
Old 04-07-2009, 12:11 PM
RC Dad's Avatar
I personally haven't had good luck setting the mambas, but they are very popular at our track. We run Tekin stuff in 1/10 scale and I find their hotwire interface much more user-friendly than the castle-link. for the extra $20 thats the way I'd go...
RC Dad is offline
