Gearing Help/ SPUR GEAR stripping ! rc18r
OK well for the past couple of times ive been racing my spur gear keeps stripping.... its soo annoying
And i need help with my gearing becuase idk alot about how to gear and make my car fast buy atm im 55/15 and i dont think thats good enough
if any 1 can help me with exp that would be awesome
the gear mesh is wrong i had the same problem and after i set it right it works awsome.i use a plastic bag and put it in between the gears and push it tight to gether.i have been running the same one for 1 year and no problems i run a mamba with a 12/55 gearing and it holds up fine.
Well no my mesh was good.. and my car is aLL stock
Suspended
Maybe try a DP gear cover from thetoyz.com It will help protect your spur and pinion from small rocks and dirt which could work their way into the gears. Also, take off the spur gear cover on the bottom of the chassis to ensure that there is no dirt or small rocks stuck in there.
Mark
Mark
how are you running your 18r??? If you are jumping with it and landing under power you can strip spur gears as well.
the pinion must be tightened parallel to the spur (motor inline w the driveshaft)
Now if your pinion is hacked....it will strip spurs as fast as you replace them.
Next time you replace your spur install a new pinion as well.
Hey i need help finding a new diff thign i cant find it at all
i need new diffs and idk were to order them i look on the toyz.
bassicly all of it my car is like making weird noises
