Vendetta Help
i need some help with my vendetta. im using a traxxas tx and rx on a stock duratrax vendetta. the steering works perfectly put im having problems with setting up the ESC. i hold down the set button and the two lights flash. then its say to make sure the throttle trim is on 0 and to leave the trigger at neutral. then your supposed to press the set button again and it will turn green. but that doesnt happen. the light just turns out and thats it. could someone please help me??
Thanks Tread |
On the bottom of the TQ transmitter there should be two small switches. These are servo reverse switches. Flip the throttle, or channel two switch, to the opposite position of where it is now. Try programming the ESC. Hop this helps.
Hmm...reading the instructions, it sounds like it should work, regardless of the servo reverse switch....is this new out of the box problem, or it was working, then developed this problem?
ESC SETUP • Center the throttle trim knob on the transmitter. • Connect the battery pack to the ESC, turn on the Tx, then the ESC. • Press and hold the “set” button until both LEDs are flashing, then release the button. • NEUTRAL POINT: Leave the throttle trigger in the neutral position. Press the setup button once; the green LED will flash. • FULL THROTTLE: Move the throttle trigger to full throttle and press the button once until the red LED illuminates (motor will not operate in set up mode). • FULL REVERSE: Move the throttle trigger to full reverse and press the button once – the red LED will stop flashing. Release the throttle trigger; the ESC is now ready to operate with your system. If the motor operates in reverse when applying forward throttle, the throttle reversing switch on the Tx must be moved to the opposite position. |
Ok here I go try this. Hold the set button down on the esc till they flash. When they flash hold full throttle the light should change then hold full rev it should change again then hit the set button to set it...I hope you under stand what i said ....um what esc is it stock one?
Originally Posted by Tread
(Post 5424572)
Thanks Tread |
yes, its the stock one. its used. thanks for the help.
