M18 cheap brushless question. >
Old 11-03-2008, 07:19 AM
Default M18 cheap brushless question.
I`m not going to participate in races with it but will this combo work?
http://www.rcmart.com/catalog/rc-bru...cPath=293_1021
http://www.rcmart.com/catalog/rc-tea...?cPath=293_946
My guess it would because both are sensorless, but ESC is for 1/10. I just want to go cheap fun. Space in car is not an issue, but compability is.
Logika is offline
Old 11-03-2008, 07:28 AM
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Your links dont work. If your looking for a cheap 1/18th BL setup, is reccomend the Castle Sidewinder system. Only $102 on tower for ESC/motor http://www3.towerhobbies.com/cgi-bin...?&I=LXURX2&P=7
geeunit1014 is offline
Old 11-03-2008, 08:30 AM
Links fixed.
Logika is offline
Old 11-04-2008, 03:53 AM
Trader Rating: 21 (100%+)
Thats a little low on the esc amp wise - the mamba 25 was 25 rated also, but Castle has said, it was really closer to 35 than 25. far as compatibility, don't know for sure, but would have the same guess.
What are you planning to run for batts?
Duster_360 is offline
Old 11-04-2008, 05:54 AM
2/3A size 1600 mah. 6 of them
Logika is offline
Old 11-04-2008, 08:21 PM
My guess is you'd be ok running 2/3a pacs, specs say thats easy for the controller you're looking at.
