Where do i find Mini-t/baja metal diffs/tranny? >
Old 09-19-2008, 08:42 AM
treeafodo's Avatar
Default Where do i find Mini-t/baja metal diffs/tranny?
Im wondering where i can i find some metal diffs or metal tranny for my mini baja? I installed brushless on it, but i have to be very careful with it or else i'll fry my tranny. Who makes a metal tranny for themini baja or mini-t?
treeafodo is offline
Old 09-19-2008, 09:02 AM
Suspended
if you installed a bl system into a stock tranny that's your problem
look into getting a balldiff and a slipper.
tons of us have been using bl for years with no issues after the proper upgrades
cracka is offline
Old 09-22-2008, 12:02 PM
PapaJay's Avatar
Don't set your slipper too tight, you will be fine.
Ball diff still need maintenance after a couple run with powerful brushless.
Maybe Losi can start produce the metal gear diff for their minis.
That can make a ton of money for them, since all their mini used the same diff. (mini lst still used it on center diff)
PapaJay is offline
Old 09-23-2008, 12:48 AM
MIP makes a grand ball differential for the mini T. I installed it almost a year ago now and I haven't had a single issue with it.
the losi ball diffs on the other hand just suck.
Sabin is offline
Old 09-23-2008, 04:06 AM
PapaJay's Avatar
I used the Losi one, the diff screw keep backing off, even with thread lock.
PapaJay is offline
Old 09-23-2008, 09:17 AM
Suspended
I agree Sabin that the losi ball diffs suck, at least compared to the MIPs, but I never had a problem with a bolt back out of my diff as long as I used loctite threadlock. Maybe you're using an inferior brand.
RCabcs is offline
Old 09-23-2008, 10:57 AM
PapaJay's Avatar
I used blue loctite, only loosen up a bit after a couple run, but that enough to make a flat spot on these ball.
PapaJay is offline
