Country alloy works still around? >
Old 09-12-2008, 08:22 AM
Trader Rating: 36 (97%+)
Default Country alloy works still around?
Wondering if they are still around and contact info if so.
ALso for the mini inferno guys has anyone tried other axles? WHat im looking for is to try to extend them a little like the kit caw made for the mlst.
Thanks any help
Savage03 is offline
Old 09-13-2008, 01:07 AM
t9dragon's Avatar
Have you tried the axles for the 09ST?
t9dragon is offline
Old 09-13-2008, 01:19 AM
Are tehy longer then the ST axles? Here is what im after, I have a old mlst axles here and their the same as the infernos, CAW made a axles widner kit for the mlst so you could run 10th scale tires on it, I had TLT tires on mine and it was awesome but theirs no way they will work on the inferno without a widner of some sort....
Savage03 is offline
Old 09-13-2008, 01:33 AM
t9dragon's Avatar
There are adapters for the Mini Inferno that will allow you to use the 12mm touring car wheels. The arms for the Mini Inferno ST are longer then the Mini Infenro ones.
t9dragon is offline
Old 09-13-2008, 01:36 AM
Correct, I have some now but their just isnt enough length for most tires tho. The caw kit actually extended the end of the axle so it helped alot in choosing different tires combos.
Savage03 is offline
Old 09-13-2008, 01:45 AM
t9dragon's Avatar
Would these work? http://www.thetoyz.com/cart/thetoyz_...9700&cat_name=
t9dragon is offline
