team assoicated 18r thread!
#1186
#1187
Ya I remember they were cheap. I had to solder my own connectors on so I like that the Pro-Match you can order with whatever you want. I actually prefer the soft packs because they are lighter and fit a little snugger. But I suppose in some cases hard packs are required for racing.
#1188
Question about the 18r,
I replaced my stock shocks for some from 3racing about 2 years ago. I've never been happy w/ the 3racing shocks, ...they don't have a smooth action/motion and seem kind of cheap (even though they are aluminum). What is the preferred shock for this car? Does anyone have the aluminum optional shocks that Assosciated offers? How are they?
#1189
#1190
Have you tried using the green slime on shock shaft from associated? The optional shocks from associated is ok it does leak just like any other associated shocks there is really not much of a difference other that quick height adjustment. I say change the seal as soon as starts leaking.
Good to know that the factory shocks are not spectacular/must have.
#1191
-oh, will try the green slime technique (I have some)
#1192
okay, rebuilt my shocks, the 3Racing ones. I have come to the conclusion that they are crap.
They look nice, but the quality is not great. They are lacking a bottom o-ring and cup to seal the shock oil, and the tolerances of the parts is off ever so slightly, enough that you don't get smooth movement. The stock plastic shocks are actually much much much better in my opinion. Going back to stock shocks for my 18r.
anyone want to buy a set of 4 3Racing shocks??
edit: they are "integy" shocks, not 3Racing. But they still suck.
#1193
okay, not much action in the 1/18th forums ...so i'll answer my own post should it help anyone in the future!
I have tried the stock 18r shocks, the ones offered from Team Integy, and the Factory Team Assosciated set.
Here are my thoughts:
Stock:
These are actually quite good, and the action is very smooth. Cost is $15 for a set of 4. For the money these are the best in my opinion. Only negative is that you can't adjust the travel length incrementally, you have to use plastic inserts.
8 out of 10
Team Integy:
These are not so good, cost was $25 for a set of 4. They leak as the design is not a great design, they don't have anything that seals the piston at the bottom so oil just leaks out. The movement is also very choppy as the parts are not precise/quality is lacking. Plus is that you can adjust travel incrementally via the threaded collars and they look cool.
4 out of 10.
Team Assosciated Factory Set:
These are the nicest, the movement is equal to the stock version, not better not worse. But you have the added ability to adjust the travel length incrementally. Also they look really nice. Negative is that the bottom cup that seals the o-rings and oil in is a real pain to remove and I honestly don't see a way to remove it w/o risking damage to this cup. Hopefully a new cup is offered in the shock rebuild kit? -I'll have to check that. Otherwise hope you never have to remove those cups. The set cost $30 for a set of 4.
9 out of 10
Stock:
8 out of 10
Team Integy:
4 out of 10.
9 out of 10
#1194
Sorry you got abandoned here on the 18R Forum. I use the actual 3Racing shocks and yes they do leak but they are my favorite. We dont run the 18r's much anymore and I really miss it. I have a great little 18R with Exotec Chassis and brushless motor and the little thing screams. I was racing it with the 1/12 scale pan car guys. I ended up buying a 1/12 scale since nobody else brought their 18R's to the track. This is mine with a couple of the bodies I've had. I didnt have a top off shot but I took a pic when painting the Nascar body. Which BTW is a great little racing body.
#1195
#1196
Looks like the only two options for 18R foams is the BSR's or the Associated's now. I cant find "The Toys" brand. They may be the same as the Associated. you could email them and ask.
#1197
I love your photos, ...yep the GT body, ...I have one, yet mine is damaged from age/use. Would love to get more of those bodies (if they ever become available again)!
I'll post photos of my ride tonight/tomorrow.
#1198
Glad you like the 3Racing shocks, ...mine are either 3Racing or Integy ...yet they are probably both the same or very similar. I just didn't like them, ...the car handled okay w/ them, but w/ my current shock setup (Team Assosciated Factory shocks) I feel the car is a bit smoother.
#1199
Ya I like the GT-Z body best too. Mine is really beat up now. I bought the Nascar body off ebay because it was really cheap. It actually worked great as a race body. I was really surprised. I do have a brand new Exotek GT-Z body I was thinking about painting up. Maybe I'll hang on to it and sell it to someone willing to pay 4x the original price LOL! you cant find these bodies anymore.
We also don't race the RC18R's anymore but I still really like the car and its super fun and fast. It always draws attention and questions at the track when I take it out for some practice laps.
#1200
Agreed!
I was happy that TA brought it back under the name of "1/18th Apex".
Yes, hoping that Exotek will do another run of the GT-Z body, ...but not holding my breath. The one GT-Z body I have had the rear wing torn off it ...I can probably fix it ..but not sure its worth the effort.
The RJ speed body that I like best is the Camaro body, -I'll post a photo, but I like the way mine came out.
