O-rings for the AE rc18b FT shocks >
Old 07-21-2008, 09:31 PM
Thomas P's Avatar
Questions?? O-rings for the AE rc18b FT shocks
Yes, i have no major issiues, i think i can feel some "bind" in the damper..the stock FT o-rings are real hard..can replacement be bought? that are softer?
any link, please
Thomas P is offline
Old 07-22-2008, 01:06 AM
crabboy's Avatar
Trader Rating: 58 (98%+)
The factory team shocks are absolute RUBISH you can buy duratrax mini quake o-rings that will fit (are a little tight but after few runs come good) the shocks are also weak as. the do not support the weight equally on each side of the car.
I suggest doin what iv done with my rc18t and mounting touring car shocks, bit more expensive but a way better shock with more options which means a better performing car
Attached Thumbnails O-rings for the AE rc18b FT shocks-img_0960.jpg   O-rings for the AE rc18b FT shocks-img_0963.jpg   O-rings for the AE rc18b FT shocks-img_0964.jpg   O-rings for the AE rc18b FT shocks-img_0965.jpg   O-rings for the AE rc18b FT shocks-img_0967.jpg
crabboy is offline
Old 07-22-2008, 01:34 AM
Thomas P's Avatar
Hmm, think il skip the TC mod..i will maybe test the Vendetta o-rings..otherwise i will pass the local "ealing company, that have a lot of nice stuff.
Thomas P is offline
Old 07-24-2008, 09:55 PM
Thomas P's Avatar
i had a little rethink about this one...do we think the TC4 fronts will fit?
Thomas P is offline
Old 07-25-2008, 01:38 PM
ae4ever's Avatar
Arrow shock o-rings
I had the same problem, but just built some AE FT shocks with integy 18T shock o-rings, they are the same size but made of silicone (should make for a smoother shock). I had a problem with the outside o-ring coming out the bottom shock cap because of the pressure when the shock is compresed, so i put the stock rubber o-ring on the outside and the integy on the inside and the shock seems smoother but time will tell. havent had the car on the track yet due to chassis problems. I also ordered the vendeta o-rings, they were too big and the recoil o-rings and they were to small. I am also looking for some silicone blatters but the more i look the closer i am to ordering the 3 racing shocks.
ae4ever is offline
Old 07-25-2008, 01:47 PM
Catalyst's Avatar
+1 on the 3Racing shocks...well worth the investment and leak free!
Catalyst is offline
Old 07-25-2008, 04:09 PM
ae4ever's Avatar
Will the stock ae springs fit the 3racing shocks
ae4ever is offline
Old 07-25-2008, 04:53 PM
Catalyst's Avatar
Yes they fit perfectly.
Catalyst is offline
