rc18t
rc18t
need help guys on installing sway bar.
do i have to drill holes on the arms? i have aluminum arms front and rear.
if someone has pix of their truck with sway bar install pls send it...
thanks a bunch
thanks a bunch
they make sway bars for the rc18t?
no they dont but they're easy to make. are you running the stock chassis or the exotek.
no pics but i will try to explain it.
i did mine with a exotek chassis with aluminum diff covers and plastic arms. i used xray swaybars and mounts. i used a dremel and slotted the diff cover right behind the two screws that hold the diff cover down. i did it just enough so it didn't get bound up or anything. put washers on the two screws that hold the diff cover on so the bar doesn't fall out. i drilled a hole in the center of the backside of the arm. the sway bar goes through the space between the tie rod and dog bone. and i mounted it to the arm.
