TEK18Xífied Associated RC18b | Indoor racer
#46
Thanks WFO, just trying to do something that i luuuv..
Rear foams are JACO pink
Front foams are VIntage TRC Orange-DOT HARD 1/12 trued ..
#47
AFTER I FINISH THIS SCALPEL IM GOING TO TRY THIS VERY NICE THOMAS
#48
If my car ever looked as nice as yours, i would never play with it.
What benefits do you get from 2WD?
#49
Suspended
#50
WFO is right
But there is one other thing, this car feels like 4wd car. im not saying it is..still driving on rears...but the layout etc on the car have some affects on the handling.
My personal opinion, this is close to 4wd.
So the benefits... handles "more" like a 4wd car
And yes, it is fun to work on them
One thing...
If i reverse the motor, and turn the rear diff 180 degrese, what affects will it have ?
One thing...
#51
Suspended
Since the weight bias of this car is more centered between the axles, some of the inherent handling issues with most 2wd's (that have a great portion of weight behind the rear axle) should be alleviated with the midmotor layout you've designed.
If you only reverse one or the other, it'll run backwards.
#52
sounds good , but would this have a different affect then to run it orginal ? i mean, the motors rotation do affect the car now, but not much, i know how to run it but ya have to keep on eye on it.
the car in some jumps or takeoffs when some trottle is still on would like to rotate some rotate direction is on the "Motor side", if i turn the motor rotation the other way wouldnt the rotation in the chassi be little less? just a tought?
#53
Suspended
While a car is in the air the axle rotation has a greater influence, since they're spinning wheels, that a driveshaft would in making a car want to spin or corkscrew through the air. At least that's the physics as I understand it.
#54
sounds good to me, but as the car want, not always at all, but sometimes, i "think" it´s when i have some trottle on the car wants to spin . and a heavier motorside, that is almost 50/50...not 100% but close.if the directional on the motor will be changed and diff flipped, wouldnt that get less,since the or tranny rotating @the other way ? should i test?
#55
Suspended
#56
Recived a copy of the speedpassion (that il recive tommorow) i mounted the replica in my 2wd car... just over 500gr rtr with body
talk about difference in weight and size vs Novak
#57
Body from GB-Concepts
#58
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
And we haven't seen a video of this little 2wd wonder car in action yet BECAUSE!?! The vid of the 4wd is killer!
#59
Sorry boys, have not the time, until Friday..and then the 24/1-09..so we´l see tomorow if this little car can stick to film ...will be intresting to test the new Hobbywing system (speedpassion)
