18r Servo upgrade
#16
You have to cut the ears off the servo and shoe goo or servo tape it to the chassis. And you will need a x ray servo saver which is the best micro servo saver around.
http://images.amainhobbies.com/image.../xra382500.jpg
#18
with my experience with the servo, the little black ring that associated thinks is a good spring for the servo saver is the problem. i got the metal rings online and the thicker one worked the best. and i ended up loosing it. is there another opiton other than the ring. different servo and servo saver?
#20
Forget the cutting, dremeling and o-ring tricks. They are not bad,just ok and there is still play. Go and get the x-ray servo saver. Hands down the best one for mini cars .
You won't regret it.
http://www.teamxray.com/xshop/produc...0Servo%20Saver
#21
The same thing we have been doing in LA. Thanks to Eddie Beltran my servo returns to center all the time. I shave the servo horn so it will not bind on the servo casing.
#22
MYRXSEVEN idea is on the money. Gashuffer's link looks good. Thanks for the information guys.
#24
Suspended
#26
Suspended
I have a couple of stockers I modded over two years ago and are still wroking fine.
perhaps you should try it before knocking it.
#28
Suspended
#30
Suspended
