rc18 same with rc18t??
Old 01-28-2008, 08:52 AM
xxx
Default rc18 same with rc18t??
hi,
anyone knows if i change some parts at rc18t can make them rc18 4wd?like towers,suspension and other parts!if yes what is the part i changed?
please i want fast reply thanks
xxx is offline
Old 01-28-2008, 10:08 AM
xxx
xxx is offline
Old 01-28-2008, 11:54 AM
rice_man's Avatar
Trader Rating: 112 (100%+)
Here's the chart from Associated on what you need.
rice_man is offline
Old 01-29-2008, 09:43 AM
t9dragon's Avatar
The RC18T is 4wd.
t9dragon is offline
Old 01-29-2008, 11:21 AM
jkas10's Avatar
Trader Rating: 123 (100%+)
Are you trying to make an 18T into an 18R rally car?
I have one I'll sell cheap if you are interested? Heck I have a truck or a rally car that I'll sell...
But, to do it yourself, you will need:
shorter front and rear arms
shorter dogbones (or cvds) x4
different front and rear shock towers
body mount set
rally car tires x4
shorter axles x4
smaller spur gear (I am having a brain cramp and don't recall the number)
shorter turnbuckles and steering tie rods (fixed length plastic is stock part)
That's all that I can think of. If going from rally to truck, do everything the other way. Make shorter stuff longer
Good luck,
jkas10 is offline
Old 01-29-2008, 11:49 AM
duneland's Avatar
Originally Posted by xxx View Post
hi,
Not sure what you are asking! A rc18t IS a rc18 4wd! What are you trying to change it into? ALL the RC18 versions are essentially the same. More parts are required to change to the 18r than any of the other possibillitiess.
duneland is offline
