EXOTEK STEERING
EXOTEK STEERING
I just put together a exotek conversion kit for a rc18t. The only probleme I have is with the steering. When I turn it to the left, and then let it go back to normal, the tires end up to the right. And when I turn it to the right, and then let go, it ends up pointing to the left. I am usuing the stock servo and the stock survo saver. Any help would be great.
Has anyone else had this problem, everything is lined up.
not sure maybe u need a new servo or maybe the servo horn is stripped
The horn is good and the servo is to.
Thanks for the help. I think the servo saver was weak or worn out, because I changed it and it works perfect.
thats good how do u like the exotech conversion for the rc18t
The exotek conversion is the best thing I have done so far. And it was pretty easy to put together.
I would have to say the rc18t because thats what I went with. But your the one buying it so go with what you like best and what best fits your application. But I am sure what ever you pick your going to love it.
well good luck deciding between the two.
Mike at Exotek says "How about getting a second one" LOL......That will solve your dilemma
Micro-Man
Micro-Man
