Lithium-ion Micro-t?
Old 12-02-2007, 07:38 PM
Xmod_Racer's Avatar
Default Lithium-ion Micro-t?
I was wondering if you dremeled out the sides of the battery holder, could you mount two of these?
http://www.atomicmods.com/Products/A...Ah__13017.aspx
If your thinking "Why not just go lipo?", this is cheaper at 5 dollars a cell. a AAA battery holder at Radioshack for a buck. but, can the micro-t electronics handle 7.2 volts?
Xmod_Racer is offline
Old 12-02-2007, 10:57 PM
raceGEEK's Avatar
it can handle the voltage, as losi lipo packs are throwing out 7.4 volts
raceGEEK is offline
Old 12-04-2007, 10:35 PM
jbligh's Avatar
Default wanting mo power
hay i was on ebay and saw that a guy has a 7.4 480mah battery for the micro check it out search li-po micro t and it should come up and they are only like 25.00 inc shipping
jbligh is offline
Old 01-28-2008, 01:41 PM
Default Lithium Ion 7.4V 750mAh Battery Question.
Hi,
I have a Lithium Ion 7.4V 750mAh battery made for my digital camera. If I used it on my Micro T with a hotter motor rated for 7.2V would that fry the RX/ESC?
Thanks.
rokit408 is offline
Old 01-28-2008, 02:22 PM
joe of loath's Avatar
Originally Posted by rokit408 View Post
Hi,
yep, as it says above, you can use 7.4v
joe of loath is offline
