1/36 Scale Losi Brushless mAh limit
im kind of a noob to electric. the 1/36 scale losi brushless system(http://www.losi.com/Products/Feature...rodId=LOSB9594) says it can handle 7.4 Volt lipo. is there a limit to the "mAh" it can handle. would this be a good battery for it? http://www.maxamps.com/Lipo-860-74-Pack.htm
Mah or milliamp per hour is really just a representation of capacity. as long as your using the stock motors that draw an acceptable amount of current you will be fine. The battery you've linked appears to be physically large for the micro t chassis, but it would work in other applications.
i have messaged max amps and they said it would fit.
