installing b1r
You solder it between the battery + and - leads going into the esc. Lay it untop of the esc to save space. You use the tiny bit of wire shrink wrap included to protect the exposed portions of the cap hitting the motor outputs.
Dont forget to solder the cap with the right polarity.
There should have been a little instruction diagram showing this included?
Heh, I reread what you said. Sorry. Personally, I wouldn't run it without. Especially with mod motors.
