-   -   Li-Po ? (https://www.rctech.net/forum/micro-mini-scales/190475-li-po.html)
gashuffer 11-12-2007 08:11 AM
Li-Po ?
I am looking to buy a Losi 2 cell li-po for my Tek 18, this batery will drop in perfectly, The battery says voltage regulator required. Is that the same as a the cut off in my Quark? Thanks in advance, I am new with li-po.
Rclesmuny 11-12-2007 11:16 AM
A regulator is needed if you are going to use this pack to
power your servos in a gas car/truck.
Rclesmuny 11-12-2007 11:54 AM
To further answer your question, No, it's not the same.
The voltage cut-off feature, 3v per cell, or 6v for a 2c lipo is to
prevent an over discharge and subsequent damage to your pack.
The regulator is used when powering servos with a 7.4v or even a
11.1v lipo pack, because only 6v with 5 amp draw is all the power
needed for this application.
gashuffer 11-12-2007 11:59 AM
Thank you.
