RC18 Speedy and Motor in MRS4 >
Old 10-31-2007, 11:40 PM
rcstunt101's Avatar
Trader Rating: 16 (100%+)
Default RC18 Speedy and Motor in MRS4
I searched but couldnt find, will the XPS speed control and motor from Rc18B fit into a microRs4? If so, what speeds will it get? Does the orion big block work with the XPS? If so i might upgrade. Cheers
rcstunt101 is offline
Old 11-01-2007, 06:19 AM
Simple answer, the XPS will work with the RS4 but the motor is the large can size and you will need to either modify the existing motor plate or buy the one that fits the Big Block (I think I saw the Big Block combo selling for less than the Big Block alone at Tower). And yes the XPS works great with the Big Block (as it should since it was designed to work with that size motor).
The Big Block in a micro RS4 will also require some chassis modification but that is all explained in Orion's instruction sheet.
AreCee is offline
