How to mount hitec 81MG on RC18T >
Old 10-26-2007, 07:40 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Default How to mount hitec 81MG on RC18T
How do you guys mount this servo on the RC18T and what do I need to have it mate up with the steering assembly?
Cain is offline
Old 10-27-2007, 02:04 AM
frogger's Avatar
Not 100% sure about the mounting on the standard RC18 as I run an Exotek conversion but the standard servo saver can be drilled a little bigger and then forced on to create new splines. Works absolutely fine that way.
frogger is offline
Old 10-27-2007, 06:44 AM
Trader Rating: 47 (100%+)
Search on " one18th.com",it's way back in the threads. I did
one a couple years ago for a friend. I like the 65MG myself.
To install the 65,mod the AE hi-tech servo mounts(a little trimming)
and widen the chassis holes a hair. Use the longer screw to mount
the servo saver(comes with the servo).Also look for the servo saver
mods. Have fun and remember to always disconnect your battery
when your done running your car (saves your lipo).
rageworks is offline
Old 10-27-2007, 09:20 AM
BadSign's Avatar
Trader Rating: 15 (100%+)
I installed a Futaba the same size, with an X-Ray 38500 servo saver. You'll have to dremel a divot out for the servo saver. Then I cut the tabs off and shoe goo it in and clamped overnight. Works fantastic!
BadSign is offline
Old 10-31-2007, 11:11 AM
gashuffer's Avatar
Trader Rating: 48 (100%+)
You do not need to dremel any divets, just put.30 shims under the servo mounts.
gashuffer is offline
