mini-t help
Old 09-24-2007, 09:34 PM
D.Lasoski20's Avatar
Default mini-t help
i have a mini-t with the stock speed control and a brand new motor and it will not work. The only way that i can get the car to move the tires is to touch the motor screw with another piece of metal. And then i dont even know if i have throttle control then because it wont stay going long enough for me to find out. If it helps the steering will only twitch if i touch the motor screw also.
D.Lasoski20 is offline
Old 09-25-2007, 12:00 AM
xsxracing's Avatar
Trader Rating: 33 (100%+)
hmmmm well it good be the esc and or the battery pack.
what esc,battery and motor do you have in the mini-t.
pm me
xsxracing is offline
Old 09-25-2007, 08:39 AM
sent pm
Old 09-26-2007, 07:28 AM
Dave G's Avatar
Is this you?? http://www.dannylasoski.com/dlroth07...iver&crew.html
Just curious....
Dave G is offline
Old 10-01-2007, 12:09 PM
yeah
does anyone else know what might be the problem, the other guy didn't reply to the pm
Old 10-12-2007, 07:33 PM
Bare Bones's Avatar
D.
I had that same problem with my mini baja. I called horizon and explained the problem to them. First they told me that a brush could be hanging up. I told them that I already replaced the brushes and springs, there was not resistance with the brushes, they would rest on the comm where they were suppose to (as far as I could see) and still nothing. So them they said that there was probably an internal short in the motor and would send me a new one ASAP.
The old motor seen 2 packs ran through it before this problem started. The new one has seen around 15+ packs and shows no sign of trouble
Bare Bones is offline
Old 11-01-2007, 08:43 PM
i had a bad motor in mine too. called horizon and they just sent me a new free motor and i never had any more troubles. give them a call, they are pretty cool to work with.
swannco is offline
Old 11-03-2007, 10:19 AM
trx1's Avatar
bet those sprint cars r hard to work on. id like to buy one, but haveing too much fun with my MQ now.
trx1 is offline
