M18 springs
Old 07-11-2007, 09:25 PM
rookracer's Avatar
Trader Rating: 4 (83%+)
Default M18 springs
I'm running foams on carpet with a firball and lipo. What Atomic springs should i be using, fronts, rear, and shock position. I'm pushing in the corners, i tried several setups but had no luck.
rookracer is offline
Old 07-12-2007, 02:59 AM
Bermbuster's Avatar
what foams are you running? 20 rear(soft) 40+ (hard) i n the fronts with atomic blue spring in the rear and atomic whites work with a 6 cell nimh set up.....depending on the lipo(weight and placement) you will have to make some adjustments to this set up
Bermbuster is offline
Old 07-12-2007, 03:18 AM
Mini_Me's Avatar
I used* the lowering springs and used blues in the rear with orange up front. However, Im actually considering that I might have needed to go even softer with a lipo setup and instead used blues up front with cut down stock blacks in the rear.
Here is my last carpet setup (pre Pro) (Works better in IE currently)
(*currently running asphalt).
We have a thread here already on the M18:
http://www.rctech.net/forum/showthread.php?t=119315
Mini_Me is offline
Old 07-12-2007, 02:17 PM
rookracer's Avatar
Thanks for the feedback guys!!!
Old 07-12-2007, 06:57 PM
geeunit1014's Avatar
for my local track i run GQ 45 fronts 35 rears and atomic orange lowering front blue lowering rear. (i run the atomic swaybar on the front as well)
geeunit1014 is offline
