LRP SPEED MOTOR????
Old 06-11-2007, 10:48 PM
iceracer04's Avatar
Default LRP SPEED MOTOR????
Does anyone know the normal operating temperature that this motor should be at?
thanks,dan
iceracer04 is offline
Old 06-13-2007, 10:37 AM
chicagokenji's Avatar
FWIW, every motor smokes out at different temperatures.
chicagokenji is offline
Old 06-13-2007, 12:49 PM
Kenji, you been smoking motors again? That won't get you high.
I've seen motors run around 200 degrees and be fine and others burnt out at 150. Go figure. Main thing is to be sure that there is no binding or too tight a gear mess which causes undue strain on the motor and shorten its life expectancy.
BTW: I'm not familiar with a LRP Speed motor.
AreCee is offline
Old 06-13-2007, 03:08 PM
iceracer04's Avatar
Thanks guys,my motor has been around 165+ so I hope it will be ok
