Arbor for rc18t tires >
Old 05-29-2007, 07:46 PM
Trader Rating: 32 (100%+)
Default Arbor for rc18t tires
Anyone know of an arbor for rc18t tires or know someone who can make one for this type of wheel?
Thanks!
racenut123 is offline
Old 05-30-2007, 12:19 PM
Thanks!
Cheater!!
Sydewynder is offline
Old 05-30-2007, 02:57 PM
You know it.
We had about 20 guys running 18th scale last saturday on the dirt oval.You should try to make it out sometime.
Old 05-30-2007, 03:50 PM
You know it.
Sorry had family thing this past Sat. Maybe next time. Talked to Terry G about it and it sounds fun but 4 sec laps.
Old 05-30-2007, 05:04 PM
Bermbuster's Avatar
I use my 1/10 arbor (4mm threaded shaft)
I use a 4mm tap and tap threads into the rc18t wheel opening (hole is 3mm) then i thread the rc18t wheel onto my arbor. The tap doesnt open the hole in the wheel.....If you dont want to buy a tap you can self tap the wheels on the arbor....you just need to use a little muscle.....you are tapping a relatively soft plastic.....
Bermbuster is offline
Old 05-30-2007, 10:38 PM
Roger's Avatar
4 second laps if you can hold a good line without getting taken out from back markers
Roger is offline
Old 05-30-2007, 10:40 PM
Roger's Avatar
Are you using an arbor for a 1/10th scale pan car foams ? I have one of these and im hoping to accomplish the same thing for our 1/18th BSR foams and Parma foams.
Roger is offline
Old 05-30-2007, 11:45 PM
touring adapter...Bring your truer to the shop Rog.With the adapters.
Old 05-31-2007, 09:47 PM
Roger's Avatar
You the man !! It works perfectly. Now I can use my hudy truer for 1/8th, 1/10th, 1/12th, and 1/18th scale foams. Thanks again.
Roger is offline
Old 05-31-2007, 10:54 PM
Can you cut my recoil foams?
Old 06-01-2007, 04:10 AM
Roger's Avatar
I probably can. Bring them in and i'll take a look at the rim's mounting area.
Roger is offline
Old 11-06-2007, 09:11 AM
MikeR's Avatar
Trader Rating: 15 (100%+)
Check it out guys;
http://www.exotekracing.com/TEAM_EXO...INI_ARBOR.html
MikeR is offline
Old 11-06-2007, 09:47 AM
Originally Posted by MikeR
Mike that is awesome. Now I have to go out and buy myself a tire truer.
rcracer17 is offline
