KO Propo 3014 Servo Problem
well i picked this servo up today and got it put in..but for some reason now when i power it up it just makes a hard right and wont move from there...i tried reversing it and get nothing...i also tried the Steering Trim and all it does is move about 2mm when i rotate it the full way...
i am using a Mamba 25ESC and 5400 motor and the stock TX and RX.... anyone know why it makes hard right upon power up? THNX Duggy |
I have the same servo!
but i don't know what the prob is i think its broken! But i have a prob to with it! I want to fit it in a M18 Pro but its to smal and what servesaver do i have to use? Greets Ollie |
but i don't know what the prob is i think its broken! But i have a prob to with it! I want to fit it in a M18 Pro but its to smal and what servesaver do i have to use? Greets Ollie As far as fitting, the Pro wasnt designed with that size in mind. However, with a bit of customization you could. If you could create a small strip of kydex, you could make a extension on the outside servo mount that makes a extended platform with the mount holes further in. Servo saver was also not designed for the sub micro servos. I have heard the sportwerks chaos buggy servo saver can work? |
my servo saver works good on it....
try the one from the RC18T THNX Duggy |
