Help picking motor
Im looking for a micro car which I use indoors and outdoors. The motor I need has to be weak enough to be able to use indoors, but has the potential for high speed as well.
I was thinking is there are any system such as the mamba system where I can make adjustments usb computer soI can control EPA to a low enough level where I dont use the full potential of the motor? any other suggestions...
if you can use the castle link, you can control the timing of the motor
Yea castle link is really cool. You can change the entire throttle curve to whatever you want. Not to mention the brake curve.
ya thats what I was thinking of using something like the castle link to make an EPA to limit the thorttle forcing me to limit the speed. I have EPA in my transmitter but not powerfull enough to really limit the speed
Limiting speed is also good if my friends want to use it. Is there any other ESC like this thats not castle creations? or is it just this that does that? thanks
links appreciated
links appreciated
