setting up the the micro t FAST
I've got a good idea about the gears. the bushings wear fast on this thing. I have run mine until bald on smooth shiny ceramic floor. at lease 100 batt. runs.
point that I've done.
- added limiters on the bottom of the shock shafts. I used rubber shielding from small cable. like what's used by mini z upgraded motors. this stops the bouncing and doesn't bottom out. it also stops the stress on the steering links
- used the motor/esc plug for a charger adaptor and extra battery. I hardwired the battery.
- Break in the motor. and then the gearbox. I added tamiya molybdenum to the bushings. the first one only after there was some significant wear. it helped. the 2nd, right from the start. it works well.
Steering links,
http://www.jimdunlop.com/index.php?p...products/picks
this is the best pick. it's the biggest and it is the best thickness.
no clips on body, velcro
four small bits.
added a mini z antena as kept the original as well.
here's a video of my micro t.
http://youtube.com/watch?v=y0MKCUL1c3Q
I'd love to hear your comments.
Happy New Year
Steering links,
four small bits.
Happy New Year
That track you made looks like a blast! I ordered 2 with bearings and extra parts off the bat. Time to get that old Ogauge train out and make a track for these lil' guys. I think a scale train hazard on a track would add hours of fun.
Hmm maybe I should order more extra parts right off. P.S. thnx for the tips...
