Cheap brushless setup for 1/18th rentals
Don't use the Scalpel because you can't get the parts they say that are available and the people you buy them from won't answer your questions.
Can we use the plane speedos like the Great Planes Silver Series 25A Brushless ESC?
How about the motor? Are there any "slow as stock" motors?
Scalpel is probably not the best choice for renting to newbies. It's a lot more difficult to drive & keep in good trim (as compaired to an Xray m18). Xray m18 with a mamba sport package on 5 cell pack would great! Performance would be reasonable and durabillity is through the roof.
I have Scalpel parts, but not to many. They are comming in every week and tires are due in this week(stock compounds only).
Aircraft speedos generally do not set-up well to pistol grip radios. They are designed to work with a full travel stick.
Carisma m14 is a fantastic choice for rental. It is ready to run for $99 retail! They handle great right out of the box and are very tough. Not brushless though. And they are a bit bigger. Still small enough for a 1/18 size track.
Since car radios have their neutral point in the middle of the throw (you get forward and brake/reverse) the plane esc might not even set-up properly since those have neutral as zero point and only move forward.
The GWS 3000K is probably the cheapest (under 25) and slowest brushless you will find. They are available through Great Planes if your a hobby shop.
could you use an air esc that has adjustible break? i would think that would give you the ability to program into a ground controler.
