Kyosho Mini-Z Series
#886
Recently purchased Mini-z Awd MA-020S after years of dying to try out Mini-z. Its a blast to zip indoors in my tiny apartment.
Now ive been racing 1/10 touring for 10years and are already very used to racing with my trusty old Sanwa M11.
Recently i have converted my FM Sanwa M11 to the FrSky 2.4Ghz hack and now would like to modify my Mini-Z to run with it.
Anyone could shed some light on how to achieve this?
Is there a way to hack the original board to accept a micro FrSky receiver or would i need to replace all the stock electronics on the Mini-Z?
Thanks in advance.
Thanks in advance.
#887
what site can i go to buy mini z's?
#889
R/C Tech Elite Member
P1Hobbies.com another great place to get mini-z cars and accessories! they have very fast shipping also.
#890
Conversion of the Mini-Z electronics might be possible, but will be extremely difficult to do cleanly so your far better option is to hack a FlySky module into your radio.
#891
I was using a Spektrum radio already with my 1/10 scale stuff. The PN Racing DSM2 board is awesome stock board replacement. Not sure what other radio's will work with it but by far the coolest thing I have purchased. Complete adjustability of settings with the bluetooth adapter is just crazy for such a small car.
#892
i wanna get back into the mini z scene
#893
Atomic RC used to install FETs on Miniz's, does anyone else provide that service?
#894
I went and bought another MR03sport to give it another try. First day at the track and the car/transmitter lost connection at about 10 feet. Did the factory reset and rebound...same problem. Tried it off the track (possible static electricity interference) and it continued to lose its bind.
I did some Internet research and tried the FlySky transmitter. It worked but only has 30 foot range (roughly) which is fine at the track I run. For $40 its a great upgrade with 10 model memory and plenty of adjustments.
From what I have read, the new Sports series Mini-Z operate on the FlySky AFHDS protocol. If you are able to obtain a FS-TM002 module and connect it to your M11, it should work.
#896
For those with sports and X-speed or PN 70t motors, did you have to get a new motor mount, or did it fit in the stock one?
Also, anybody using an aftermarket ball diff? I'm trying to figure out which ones will work. I have a 98mm MM chassis, I believe.
#898
PN 70 turn is not compatible with the sport board; you run the risk of blowing out the board.
#899
I thought it was OK as long as it's more than 50 turns? Will upgraded FETs fix it?
What about the X-speed motor, any issue with using that on the stock sports board?
#900
Just to be sure I did check the Kenon Hobby site which did confirm the 70 turn motor is not compatible with the MR03 Sport board. I have heard upgrading the FETS will solve the problem but I do not have first hand knowledge. Regarding the X-Speed motor; the MR03 Sport packaging does list it as a compatible part. I have not tried it on one of my cars but it does sound like something I would like to pursue.
