Kyosho Mini-Z Series
#7411
Hobbytown here has no limit to what you can have? Bring what you bring kind of a thing? Kenon Hobby? Don't you have to email him? Or can you just order online? Thanks. No Rules.....
#7412
So this question is about the Atomic AMZ, not a mini z but I thought maybe you guys could help. I am unable to get this car to corner the same left and right. Mine always spins to the left on hard cornering. I tried all different preload setups, swapping tires, adjusting droop screws. No matter what I do it always spins to the left. The car is weight balanced, diffs are super smooth, loose in back, ever so slightly tighter in the front. I'm super frustrated now😡🤬
#7413
Not sure if they have fixed the flaw, but the bulkheads are a bit off. Camber is not the same on both sides. Cross corner, one side will have negative camber, opposite positive. I remedied this by using different camber arms and a camber gauge to set the camber. It still has issues of different arm length changing the roll center and camber gain, but it drove a lot better after that change.
Check your camber, and see if that is the issue. If they remolded the bulkheads, then it may be something different... but odds are that they are the same molds.
#7414
I have a kit from last year, the problem was still there, I think I made it a little worse with the wide CVD kit. I got the link kit too, messed with it a bit, but ultimately put drift tires on it, didn't have the time (or patience) to get it consistent on RCP track.
#7415
You guys are right. Rf and lr have negative camber. Lf and rr have 0 camber. Thanks!!
#7416
Even with the camber problems my AMZ drove great when I got everything freed and moving smoothly. For the Mini96 track the hyper steering helps a lot.
#7417
The new MR-03 rwd ESC can only handle brushed motors to what turn? Or can you use brushless motors? If not, what ESC are you guys using? Thanks for the info.
#7418
For the current mr-03 (i.e: white antenna with mini-z fhss protocol), you can use the kyosho xspeed v (MZW301) or PN 70t safely. There are stories of people using the PN 50t, but I think it can draw more amp than the main board can handle.
Since mr-03's electronics are all integrated, you can consider replacing the board with an evo board (brushless and brushed, with better fet), old asf board (can handle a bit more amp). Changing the esc to something non-mini-z would be quite involved as it would involve a servo controller and fitting everything in the chassis. At that point, you might as well go with non kyosho cars such as GL and Atomic.
I have both brushed mr-03 and brushless mr-03evo. They are fun in their own ways.
#7419
Thank you very much. That's just what I needed.
#7420
Just some other info for coverting the MR03 to open electronics. The short answer is it's doable, but there will be modification done to the chassis depends on your choice of esc. I used a dasmikro's brushless speedo, because this ESC is wider than the original boards with MR03, I had to cut a slot on each side of the chassis, right behind the second "Hook" for battery clip, then I had to grind them down flat and basically jam the esc between the chassis and top plate.
As for the servo, both dismakro and Pn sell servo boards that will allow you to covert the servo motor and pot's wires into 3 wires that u can directly plug into a rx normally used with this scale.
The most messy part is to wiring the entire front chassis right, because now u will have to deal with cables form ESC, servo and rx. In my case, I choose to put the receiver on top of the chassis and passing cables from the slot in where the ICS port used to locate. This coversion isn't really fun due to the amount of soldering and cable management. Also, now there are aftermarket rxs made for Miniz Evo that covers bascially all the mainstream radios on the market. I really don't think doing this kind of coversion is worthwile anymore, too much work and chassis cannot be reused if you want to undone this conversion. Plus, using a open chassis from Gl or Atm makes more scene if u need to have more powerful electronics. The lipo battery alone will make acceleration a lot faster.
#7423
With “box stock” tires are usually the only thing that can be changed
