Kyosho Mini-Z Series >
Like Tree1707Likes
Old 09-15-2020, 05:57 PM
  #6901
EMU
EMU's Avatar
There are benefits and drawbacks, but overall the advantages are much stronger. The primary benefit is stated above. Much less friction surface area. This allows much less binding on suspension travel. The stock knuckle in particular binds up pretty quickly.
on to the negative. Mass of the ball end is now raised to above the arm rather than below it and is now unsprung mass. Unable to limit suspension down travel. Less friction can lead to a faster reaction of front suspension. To mitigate this, I use a little grease between the kingpin and lower ball. I usually use a dab about 1mm cubed, applied with a toothpick periodically when assembly is already built and suspension raised (above lower ball but below knuckle/shims) then work it in and wipe off excess while suspension is lowered. This helps calm the cat and reduce chatter. It is less consistent greasing the upper ball and knuckle on the standard configuration. I use the same method for the GL-Racing GLR which by default comes with the kingpin fixed to the upper arm/ball.
EMU is offline
Old 09-16-2020, 05:52 AM
  #6902
Billy Kelly's Avatar
After a little practice
Tim3 likes this.
Billy Kelly is online now
Old 09-16-2020, 07:56 AM
  #6903
I may just polish for the time being and cut later. I have no cutting tools and dont want to mess it up! Thanks EMU!
maxwellduryea is offline
Old 09-16-2020, 03:25 PM
  #6904
The reason for cutting is once you invert them, the non-ball long end hangs out the bottom, and will drag on the track if you don't cut them. I use a full size set of wire cutters and just snip it off a little past the e-clip ring. I install them hanging out, mark them with a Sharpie, take them out and cut them, put them back in. Where you cut is somewhat critical, there's not a ton of margin between too long and dragging on the track, or too short and falling out of the ball under high load. Ideally, there's just a little nub, maybe 1mm that hangs out the bottom when sitting neutral.
EMU likes this.
superfly05 is offline
Old 09-16-2020, 06:50 PM
  #6905
fast_gc8's Avatar
I might be selling an MR-02
fast_gc8 is offline
Old 09-17-2020, 08:56 AM
  #6906
EMU
EMU's Avatar
I just use small pliers, and snip where the c-clip goes, then file down the tip so it's smooth.
EMU is offline
Old 09-19-2020, 02:35 PM
  #6907
Any detail shots of said procedure?
Old 09-19-2020, 03:54 PM
  #6908
RCSteveH's Avatar
Just did mine today. Itís so much smoother. Zero bind. Iím getting rid of the aluminum arm and going back to plastics. It sucks cause I have 5 sets of them 😩
EMU likes this.
RCSteveH is offline
Old 09-21-2020, 03:42 PM
  #6909
https://youtu.be/EiuJIMqYH78
Billy,,,I like your track. Nice job !
Tim3 is offline
Old 09-21-2020, 04:38 PM
  #6910
Iím suprised it works. The blind spots arenít too bad.
Old 09-23-2020, 12:20 PM
  #6911
Trader Rating: 16 (100%+)
https://youtu.be/RMt8zE41CJ0
MZW413 and MZW433 free up the stock orientation. They also work in the flipped position, but elimiante any need to polish the joint locations.
EMU likes this.
chjosi is offline
