Kyosho Mini-Z Series
#4651
If you want to get the most bang for your buck with simple tuning options, I'd look at more broad strokes like getting a couple different types of tires (super soft, soft and medium for fronts; super soft and soft for rear) and a couple different T-plate options, see what works best for your driving situation. Also consider a disc damper if your car doesn't have one.
I find things like springs, disc damper settings, knuckle camber are more for fine tuning and eliminating specific issues.
#4653
Just finished my home built track over the weekend using EVA 600mm x 600mm foam tiles. The track size is 2.4m X 3.6m with a lane width of 480mm. The foam mats have a rough and a smooth side. I am running on the smooth side. Its pinned together with timber dowels. In hindsight, I think plastic wall plugs would have worked better as theres 270 dowels cut at 20mm each.
RCP tracks are way too expensive in Australia compared to the US. A mini96 in Australia is approximately $550 USD shipped vs $199-230 USD in the US. My track build has cost me a little over $100 Australian dollarydoos or $70 USD.
I havent driven a rc car on a track since 2014 so I had a bit of learning curve with the mr-03 evo 12000kv. 17.5 boost was the norm for stock (great times)and we were changing to 13.5 blinky stock (meh). So far I have noticed:
1. 12000kv is waaaayy more power than I need on such a small track. I turned throttle down to 50% and even thenl, its a handful.
2. The EVA track barrier I used will stop a car dead in its tracks when you brush up against it. This makes the track feel very narrow as you need to stay away from the track barriers.
3. The mr-03 has a lot of steering. I need to get used to how quickly it changes direction.
4. I want lap timing.
#4654
Hi guys, how are you? I need little help.
1) I have kyosho ve pro unit and I want to ask if anyone know how I can check if unit works well and gives me the power it can . Because I think that doesn't give the write power to motor.
2) can I put other fet better and for more power?
3) the more powerful 3500kv motor for nimh batteries
thank you
thank you
#4655
Try turn down the steering dual rate on your radio. If break end point is available then you can also play with it. For me, the main problem is when under heavy braking, mr03 has the tendency to spin out or over rotate. I have to turn the EPA to 30 but then the brake seems a bit weak for me.
Can't help with the motor problem though. EMU who frequent the tread used to say that on nimh, 5600 will be fine and on lipo 3500 is all you need for this small track. I'll get my hands on a mr03ve with blue eco this week and I'll see what's gonna happen.
#4657
#4659
Just replaced stock motor on mr03 with a PN Racing 70 turn motor and it's a lot quicker (and louder!). Any tips out there on how to quiet these down? Currently running an aftermarket diff, but not sure which one. Few other questions: recommendations for spur/pinion tooth count?,,just running on rcp-like track...looking for a good all-round setup. And finally, broke one of the plastic motor plates so now thinking of upgrading to aluminum PN Racing motor mount...any recommendations on those? Cheers!
#4660
She's finally arrived. Seems like I picked up the original mr03ve. I noticed that the ics 1.7 bluetooth software states there is an issue with the software and refers me to the Kyosho development blog, but I can't find the blog post. Does anyone here know what's the problem with the software?
And I just can't have enough MP4-12C....
#4661
the PN pro match pinions are much quieter than kyosho molded ones since they are machined. Proper gear mesh/ lash will quiet it down considerably. Gear differentials are louder than the ball diffs as well.
#4662
I think XRX also has one, but not sure if it is released yet.
http://godracing.com/index.php?route=product/product&product_id=128
#4663
I am still confused what these shims are used for but I am guessing they help when you take shims off of the kingpin for a lower ride height.
Cheers,
Jim
#4665
Thanks Jim, then these shims are somewhat pointless as we can put normal shims on the original plastic shims to adjust ride height, should be a lot more affordable than the r246 shim sets and do the same things... Just my thought,
