Like Tree819Likes
Kyosho Mini-Z Series
Old 12-27-2018, 08:04 AM
  #2671
LJH
There is also this one which I kind of like, reminiscent of the mid/late '90's WSC cars.
https://www.shapeways.com/product/GM...li=marketplace
Cheers,
Jim
LJH is offline
Old 12-27-2018, 08:07 AM
  #2672
Billy Kelly's Avatar
Cheers,
Jim
For some reason those open cockpit style cars never looked right to me. Maybe if Iíd seen that style of racing more Iíd have gotten used it to. But for most part only see it few times a year.
Billy Kelly is offline
Old 12-27-2018, 08:25 AM
  #2673
LJH
I hear you but I still think there have been some very pretty open cockpit prototypes over the years.
Cheers,
Jim
LJH is offline
Old 12-27-2018, 10:47 AM
  #2674
Is there any other option besides the PN 70t Motor? Can’t find a single stock motor anywhere. Kyosho America has nothing.
Starting to think the PN motor vehicle I’ve been using is just not right. Lost throttle few times last night, no forward or reverse. Motor wires screw are tight. But it’s starting to get longer now till throttle returns.
Old 12-27-2018, 12:30 PM
  #2675
mleemor60's Avatar
Trader Rating: 28 (100%+)
Is the little yellow thermal breaker still installed? Remove it.
What are you looking for as far as motors are concerned?
mleemor60 is offline
Old 12-27-2018, 01:23 PM
  #2676
I hate the drag brake effect mine has had. After 2 months of us itís only slightly less. Lift though a turn and the rears lockup. Performance is only slightly better then the stock so far for me. Maybe I got a bad one, thatís what Iíve heard from others in the 1/28 group. I just basically donít like how itís changed how the car drives.
Old 12-27-2018, 01:35 PM
  #2677
lmlindbo's Avatar
The pn70 has got a lot of dragbrake, unfortunately.
​​​​​​Have you tried to change brushes? They wear with use, and give dead spots so you don't have power.
lmlindbo is offline
Old 12-27-2018, 01:41 PM
  #2678
lmlindbo's Avatar
Building cars for the kids.
​​​​​​Pretty cool when you have raced for so long that you can build three cars from spares😉
I even found my old RR front.
EMU likes this.
lmlindbo is offline
Old 12-27-2018, 02:10 PM
  #2679
Iíve never pulled a motor apart on any scale.
The power lose thing is separate. Some times off a hit against the rail I just loose reverse and forward. Returns after about 10-15 seconds.
I get that these are the upgrade over stock. And maybe with a gearing change, it would be much better on the big track. But at most Iíve got 8-10 possible chance in next 5 months to run big track. Then nothing till fall. Where I can use my home track every night potentially. And on my track there only a small difference between stock motor and the PN.
Old 12-27-2018, 02:17 PM
  #2680
lmlindbo's Avatar
The stock motors are approx 80t. But some of them are fast as stink.
lmlindbo is offline
Old 12-27-2018, 02:34 PM
  #2681
didnít know that. I thought the stock motor were also 70T. I just donít want to end up running a motor I donít like in all cars in future. Problem is nobody has the stock motors available. Which I see as a big red flag for the overall state of Kyosho. My others donít have any problems currently, but all it takes is a broken wire to change that.
Old 12-27-2018, 02:46 PM
  #2682
lmlindbo's Avatar
Made this just for you. ;-)
Sorry about the bad quality, only had my phone available.
Get motor out of the car and solder of the wires.
When you solder back on, make sure the red one is on the side of the text.
The first brush I pull has done its job. When they get that low, they can have issues with starting.
lmlindbo is offline
Old 12-27-2018, 02:51 PM
  #2683
lmlindbo's Avatar
When it don't want to start after a crash. Try spinning the wheels. If that helps, your brushes are gone.
lmlindbo is offline
Old 12-27-2018, 02:56 PM
  #2684
https://youtu.be/B1qpXyqFfTw
ill try to get the video to play tonight. I have zero soldering ability. Itís been on my list to learn. But havenít figured out a good way to practice. Watched more how to videos then can count. But Iím missing something when I try.
Old 12-27-2018, 02:58 PM
  #2685
mleemor60's Avatar
Billy, just a couple of questions. What pinion and spur are you running? Is there any backlash at all between the gears? Is this the FWD car or another? Are you using bearings or bushings in which the motor pod? When was the last time you pulled the rear axle out and cleaned the hair accumulation from around the axle? What transmitter are you using? You may have covered this but I must have missed it.
