Kyosho Mini Inferno
#16
Originally Posted by Scrad
Nevermind I wasn't paying attention and noticed that there are holes that are farther out.
I'm having problems setting up my mamba with my spektrum. It won't recoginze were nuetral is at. If I take the plug out of the rx and put it in a different channel it sets nuetral but then the whole thing is thrown off. I don't get it.
I have had problems with mamba ESC not recognizing neutral before too. Try resetting ALL of the trims on the radio back to zero (neutral) and see if it will set. I can't remember which one I had the problem with, but it was one of the trims. Another guy at the track last year had the same problem...we moved the throttle/break trims around on his R-1/spektrum and got it to set. Just play with them...you'll get it.
-David
#17
I ended up getting it set by setting my sub trim forward to around 95. It works now. The only thing I've noticed is that if I mash on the throttle sometimes is doesn't move and stutters. Then gets hot. Otherwise it seems fine.
What pinion should I run with the comp x. I put a 10t, because that is all I had besides the stock gearing.
#20
Ah, I think I can be of assistance here. As of now, the absolute best motor/ESC combo for the KMI is the Wraith 7k/Quark 33A.
#21
Finally found the site. What made you decide to get my recommendation? I'm glad you found what's best for you too.
#25
Originally Posted by fav0re
I have a Lipo setup and will post vids of how stupid fast it is.
Here are some videos I promised with the Quark 33A Pro Car, Wraith, Hyperion 1800mah/2S, Proline CrimeFighters, stock front diff, and 3Racing center/rear diffs( rear is f*up due to loose settings, you can hear it).
VIDEO LINK
#26
Registered User
Anybody heard when the nitro version is coming out?
#30
