Official AE RC18 Thread! >
Like Tree1Likes
Old 01-12-2009, 01:52 PM
  #1111
cwoods34's Avatar
That was just the quickest and simplest example that came into my head
And I'm looking at trying an MIP spool for my 18R, what are your thoughts? I've never owned a vehicle with a spool/one-way, and I won't' say that it needs it but it could be worth trying out. I've driven a friend's TC3 with a one-way and it liked to be driven much more aggressive through the turns than my TC4 running diffs at both ends, and I was thinking I might like that driving characteristic for my 18R.
cwoods34 is offline
Old 01-12-2009, 03:19 PM
  #1112
clamber's Avatar
What the heck is a spool? lol
clamber is offline
Old 01-12-2009, 04:22 PM
  #1113
clamber's Avatar
Does anyone know why my 18T accelerates faster in reverse than forward?
Also, if the front of the truck is as high as it can be, about how high is it?
clamber is offline
Old 01-12-2009, 06:41 PM
  #1114
Suspended
Still?
You did something wrong.
About that high.
WFO7640 is offline
Old 01-12-2009, 06:51 PM
  #1115
Trader Rating: 67 (100%+)
A spool usually allows the front wheels of a four wheel drive to free wheel when the brakes are applied. This allows you to have braking without locking up the front and causing a spin. Often used in touring cars.
If reverse is faster than forward it would sound like you need to reset your radio and ESC.
Max height would depend on the springs, oil weight, and how many shock collars or how much you tightened down the threaded collars (if installed).
nutz4rcyktw is offline
Old 01-12-2009, 06:58 PM
  #1116
Dob
Dob's Avatar
FIrst part - Check your controller. Make sure your throttle endpoints are all the way up and what not, or if you have a Sidewinder (thought you did) try to reprogram it. Under full throttle make sure the light is solid green for forward and solid red for full reverse. Yellow is neutral.
Second part - If your still having this issue, (not sure if this was posted), How your shocks are mounted plays a roll in ride height. If you want it level move the shocks around (dont ask how just figure it out!!).
I have no problem answering questions but as others have stated, there is a lot of things that you just need to look at yourself and figure out on your own. RC requires trial + error and plenty of exploration! Good luck and exhaust all possibilities before asking help. You will learn a lot more a lot sooner.
Dob is offline
Old 01-12-2009, 07:09 PM
  #1117
clamber's Avatar
Yeah I tried everything I guess Ill just deal with it.
clamber is offline
Old 01-12-2009, 07:51 PM
  #1118
cwoods34's Avatar
So you tried....
Different springs, different amounts of spring preload, different oils, different shaft lengths, different internal spacers, different mounting positions, and running all combinations of front/rear shocks?
You can put long (rear) shocks on the front ya know.... just experiment.
Did you ever think running long-shafts in the front shocks to give a little more height?
Think of it like math. You want to get the number 2. How many possible ways are there to get the number 2 as an answer? There's more ways than just 1+1 (that being the obvious first choice).
cwoods34 is offline
Old 01-12-2009, 08:00 PM
  #1119
clamber's Avatar
Originally Posted by cwoods34
So you tried....
Lol when i said that I meant I tried everything about the reverse accelerating faster.
Ill need to take another look at the front shocks and see if theres anything Im missing
clamber is offline
Old 01-12-2009, 08:01 PM
  #1120
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
What you described is a one way. A spool is a solid axle which delivers power to both front wheels evenly 100% of the time. Can be useful in tight tracks where maximum pull is needed out of the corners. Not good for throttle happy bashing tho. A spool can put tremendous strain on the drivetrain.
SpraydbySprague is offline
Old 01-12-2009, 08:52 PM
  #1121
trerc's Avatar
Trader Rating: 89 (100%+)
True, and even more so when there's an abundance of traction and your really putting the power down such as in carpet oval.
trerc is offline
Old 01-12-2009, 08:57 PM
  #1122
Suspended
+1
WFO7640 is offline
Old 01-13-2009, 10:22 AM
  #1123
iPearl's Avatar
Trader Rating: 96 (100%+)
Do ppl use spool for Offroad Rcs ???
I know we used to use spools for onroad drifting on 1/10.
To lock up the rear, and paired that up with a front one way.
But, all it was good for, was drifiting.
For Reg racing, it wasn't to good unless you were on a straight line.
If you going faster in reverse try to see if ur remote has a switch to swap fwd and reverse.
My old Transmitter had that and reverse was never at 100% (75% normally)
and my forward was 100%. and when i had it set up wrong it went 75% fwd and 100% reverse = Rev faster than Fwd.
This happens if you have JR equipment in the RC and run airtronics radio since their signals are inversed.
And ofcourse other brands...
Try that ...
PS: Reprogramming the ESC is required after flipping that switch !!!
iPearl is offline
Old 01-13-2009, 10:57 AM
  #1124
Dob
Dob's Avatar
Deal with a improperly functioning vehicle? You paid for it, take the advice you are asking for and figure it out. Did you make sure you were getting the proper lights on the ESC as I stated above. If the lights are OK the reverse forward "problem?" may be a figment of your imagination.
Dob is offline
Old 01-13-2009, 11:29 AM
  #1125
pull-start's Avatar
Trader Rating: 27 (100%+)
I agree 110% with Dob. I would tear it down again and rebuild it. Can you rebuild it with the help of someone who has experience with building kits?
pull-start is offline
