Official AE RC18 Thread! >
Like Tree1Likes
Old 12-22-2008, 06:09 PM
  #796
RCSteve93's Avatar
Originally Posted by WFO7640
Those are actually 3Racing treads and rims.
Some guys jumped all over them because they were the first aftermarket offering, and some even claimed the had a little more grip than the stockers.
But foams are definately the way to go if you're racing.
Ok, cool. Thanks. I guess I will go with foams for racing. I bought those because they were too good of a deal to pass up...
What is everyone using for foams?
RCSteve93 is offline
Old 12-22-2008, 06:39 PM
  #797
cwoods34's Avatar
BRP's, even the rally cars use truck axles to be able to run BRP's (me included). They seem to be "the" tire at my track. I also sold a set of Associated's foams trued waaaay down to someone who uses them on his rally car also, they function much like the BRP's but they have a little bit too much side bite for my liking.
And honestly the pink Losi foams for the Mini T aren't bad either, I had to drop my ride height due to them being untrued, and most of the time I didn't need to use dope because they grip so much.
cwoods34 is offline
Old 12-22-2008, 07:36 PM
  #798
myrxseven's Avatar
Oh yeah, the associated foams will be a lot better after being trued. But either way foams are still better than rubber.
myrxseven is offline
Old 12-22-2008, 07:47 PM
  #799
Trader Rating: 28 (100%+)
So what is a good brushless system that won't break the bank for these cars? I'm going to run it stock for awhile, but would like to know what is out there.
jbrow1 is offline
Old 12-22-2008, 11:30 PM
  #800
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
So how are the foams for outdoor asphalt racing? I heard that some of them are only good for a few laps. Any recommendations there?
IIGQ4U is offline
Old 12-23-2008, 06:33 AM
  #801
Suspended
of course, foams are notoriously fast wearing on asphalt and why most run rubber tires outdoors and save the foams for carpet or get harder foams
WFO7640 is offline
Old 12-23-2008, 06:38 AM
  #802
Suspended
not a good idea since there are rally-sized options that have a smaller diameter and lower profile and allow a lower COG
BRP or Losi foams, even trued waaay down kinda ruins the whole idea of running the larger foams in addition to forcing you to whack out the wheelwells to get them under the body
WFO7640 is offline
Old 12-23-2008, 09:14 AM
  #803
clamber's Avatar
I am really wanting one of these.
For $300 what all should I get?
clamber is offline
Old 12-23-2008, 11:42 AM
  #804
hey guys . I'm having a problem with my son's rc18r . I just got it the other day and the speed controller was bad . So I went and replaced the speed controller with the oem controller and it ran great for about 5 min . Now it is acting up again . It will not go forward with full throttle and it will go slow with partial throttle . What do you think . Thanks
obscenelegacy is offline
Old 12-23-2008, 12:06 PM
  #805
cwoods34's Avatar
@WFO yes it gives up a smaller diameter wheel but it is also wider than the rally tires which is why I use them. I even raced my 18T with 18R foams for awhile and it drove good but it wasn't like running with BRP's. Plus I think they cushion a little better for our jumps. But if you aren't running jumps then of course get rally specific ones.
There are ways I compensate for the taller tire. I've done about anything you can do to shocks and the ride height and if you can set your roll center properly it helps, too.
To each his own
cwoods34 is offline
Old 12-23-2008, 12:09 PM
  #806
Suspended
Have the knobs been moved on the controller? that could be inhibiting things.
But usually ESCs are a go or no-go item, either they work or they don't -
and considering your previous problem I'd want to guess it might be traced back to the motor. It could have been bad from the beginning and torched the first ESC, hung up brush or something, and now it's giving problems again.
WFO7640 is offline
Old 12-23-2008, 12:13 PM
  #807
Suspended
To each his own
I totally get what you're saying if you're running it as a 18T, but I think if you had a 18R you'd immediately notice a problem with getting the larger 18T tires in the wheelwells without either jacking the body WAY up in the air or chopping up the body and hacking it up to make room (been there done that )
WFO7640 is offline
Old 12-23-2008, 12:18 PM
  #808
cwoods34's Avatar
That's why you get the Exotek 350Z and just cut the wheel wells a little larger than normal
A guy I race with had the Skyline body with BRP's, it didn't set up high like a monster truck nor did the body look hacked. Maybe he just found the perfect balance
Or just buy the DP Scorpion short-course body and solve all tire-body problems.
cwoods34 is offline
Old 12-23-2008, 12:29 PM
  #809
Suspended
If you say so
I guess some guys don't mind wheelrub.
I've got a skyline body sitting here that's useless, wheelwheels cut almost to the hoodline, I can let ya have for cheap make that free.
WFO7640 is offline
Old 12-23-2008, 12:57 PM
  #810
I hooked one of my larger 7.2v batteries off my traxxas to the motor on the ae and it seemed to run great with the power going directly to it . Could a bad battery cause this ? This is my sons rc car and want to get it running problem free so the wife don't kill me for buying him a car that keeps breaking . Thanks for all the help .
edit
its fixed . I just put different plugs on it and now using my big 7.2v batteries from my traxxas . This damn car has never went this fast with the stock battery . Thanks
