Official AE RC18 Thread!
#616
Just purchased an 18T chassis kit from Diggity and will be beginniing the conversion next week. I'll be posting pics and updates along the way so if anyone else is doing this conversion, has done it, or is interested in doing the conversion follow along and any/all words of wisdom are appreciated! Here are a few of my 18T after disassembly, during, and the kit itself!!
#618
Thanks for the quick reply. One thing I would recommend on the Diggity setup. Get yourself a set of 3racing suspension arm mounts, especially on the front. Since I race oval, I use 3 degrees in front and 0 in the rear.
#619
Thanks for the tip! I'm just in the build process and I did put aluminum pin mounts in the front as per Diggity recommendation as a starting point. I might pick up a few different arm mounts for experimentation. Our carpet season is coming up and I'm really amped up about it this year
#620
The oval that I'm racing on is best described as a flat Bristol. The straights are only maybe 40 feet long. We turn about 90 laps in a 5 minute race. I first started out the a zero degree mount in the front. The car had a lot of understeer with it. When I went to the stock 3 degree's the understeer was completely gone. It actually turned into the corners too well.
#621
I figured there would be a difference in the steering especially on carpet but didn't think there would be an understeer issue. Thankfully we'll have some test/tune time before the season really get going. Our track is pretty tight with a straight about the same length as yours. Are you using the stock diff's or upgrades? I have a pair of MIP's on order.
#622
Other than the Diggity Chassis, my car is pretty much a box stock Factory Team. My next project is to build a Super Late Model for this season. I'm planning on getting the Diggity oval chassis, sway bars, LRP Fusion motor, Tekin B1 ESC, plus a few other things. My current late model is pretty fast with a stock motor (current track record holder), but I wanna see what a car that is really prepped for oval racing would do.
#628
which is better in durability and speed wise. the vendetta st or 18b
#629
rc18t jump anybody?
