Official AE RC18 Thread!
#1982
#1983
Picked up my 18t 7 years ago, my first hobby grade rc. Fun little car, I take it almost everywhere and run when I can. Currently running hobbywing esc and 7800 kv motor geared 12/60. I puffed my 3 year old lipo but my 18t still does about 35mph on nimh. Getting ready to swap a new chassis this winter, cracked the front of the old one.
#1984
Its funny how these trucks/buggies are still in demand. Too bad there's only a handful of places to race them!!
#1985
There is an indoor track somewhat close to me, last time I was in the attached hobby store they still raced minis, with the 18t being the most popular. I may need to make a trip over there and at least try their track. They rent track time to the public, is that common?
#1986
#1987
Feeling bad I let my 18t go so long without maintenance, it was my loaner all summer as I was into my sc8.2e this year. One of my ft shocks got all bound up, looks like the anodizing piled up at the middle of the piston stroke. Is that possible? Shock body has an obvious ridge insidea that binds the pistion. Diffs are both used that I threw in after my 2 nephew's melted both in july. Not to mention the cracked chassis, bent hinge pins, balding tires and I'm sure there's more.
That little hobbywing 35a esc and the 7800kv motor have taken some serious abuse and not a beat missed. Nephew's had the motor at 200f a couple times and I generally run it up to 170f before I stop for a break.
So much abuse this little truck has taken.
#1988
Stock 18r with stock esc/radio - forward throttle works fine - but when I press the throttle trigger forward for brake and hold it there - the vehicle slows and then goes immediately into reverse? Is this normal for this esc/radio? I have reset the esc numerous times with the same result. It does not have the normal press the throttle forward for brake, return to neutral, press forward a second time for reverse - it just slows and then goes immediately into reverse. Any ideas? Thanks!
#1989
#1990
18t rebuild on hold until parts arrive. Thought I had all the parts but found the top plate broken at the front diff. That's what I get for letting the cracked chassis go for so long, to much flexing caused the plate to snap. Complete new differentials, rebuilt cvds, replaced numerous bearings, hinge pins and a handful of bent screws, not to mention new chassis and now a top plate.
#1992
They might allow it on a really slow night.
You will be much slower than the 1/10 trucks so you will be in the way, if there are competitive racers there that are turning fast lap times they will not want you in the class.
Your best shot at getting it on the track is in the novice class that allows any vehicle.
#1994
Yeah, the lap times are much slower than 1/10. They are fun and a dedicated class would be a blast but you would be an obstacle in a 1/10 race.
One of the tracks I race at started a 1/16th losi buggy class and a bunch of people bought them. It died off in about 4 months but those did turn pretty quick times. Those guys were turning the fast laps in 1/10 so they could race a radio shack RC competitively
#1995
Top plate came in yesterday, rebuild complete! Ended up replacing nearly every screw in the front end as they were all bent. Dog bones in the rear were original, not much left so I replaced those too. Adjust the diffs and it's ready to go for another 6 years.
