Official AE RC18 Thread!
#1501
Check out the Tekin Rage systems. I just got one for my 18B. They are a little more expensive, but I think you pay for what you get. Depending upon what you want it for, the 6900 will be more than enough. The 8000 is way to much power for most.
Kevin
Kevin
#1503
The Mamba system is well rated by many on here. I do not like Losi very much, but that is a personal preference. I have also been looking at the Sidewinder/AON motor combo. I try to support the local folks here in Idaho, that was the main reason I went with Tekin.
Kevin
Kevin
#1504
When I had my 18t I ran the Mamba. The computer link that comes with it is the best. It make adjusting the speed control sooooo easy.
#1505
If anyone has a 18B roller and is looking for an 18R roller send me a PM..
#1508
On the stock transmitter it has knobs for Throttle ATV High Low?
Out of the box they were set to the middle, arrows pointing 12 o'clock
Where should they be set so my throttle or braking is not being restricted?
I'm soo OCD about that i'll often redo the settings more than once. I just don't trust it heh...
#1510
I purchased the blue Dp gear cover and from looking at pictures and video of it I can't tell.
Does using this make setting your gear mesh impossible?
Thanks i'll try that.
The Steering EPA is handy. It's nice to be able to dial back the steering.
I said forget about the stock radio and grabbed a spektrum. I've wanted one for a long time.
#1511
Well, thought I would try something new this past Saturday. Typically I race my 18T with 2 ball diffs and foam tires (1/12 adapters).
I found a set of the stock rubber pin-tires that are basically slicks now from being worn down. I cleaned them off with Greased Lightning, re-glued the rims, then let them soak through 3 coats of Paragon.
I also put in my MIP fixed one-way. For those who don't know what that is, basically off-throttle it allows the front wheels to free-spin, but on throttle it is a locked axle. Fast 1/10 rubber TC's use spools and fixed one-ways.
I swapped springs and put blue on the front, gold on the rear.
I was worried about the tires losing their "stickiness" near the end of a 5-minute heat, but they didn't. I never had any problems with them losing traction, slipping, getting loose, etc. and our carpet is only about medium traction.
I was running faster times with my new rubber setup than I ever have with a foam setup. The AE rubber tires also made jumping much more forgiving.
BTW, the powertrain is Mamba 6800 and 1600 NiMh Orion pack.
I placed 2nd to my friend's very fast 18R on foams, but it wasn't due to lack of speed. I ran the fastest lap of the night in the A-main by about a full second over anyone else. I was having problems with the ball cups stripping from the turnbuckle so I probably sat out 3 laps because of it.
Definitely give the setup a try if you have the parts. I was running 60 wt. oil in the front, 40 wt. oil in the back, with arms level all around, 1* toe-out front, 0* toe rear. Camber is 1* all around, but I plan to try 2* in the front due to the rubber tires rolling more.
You could possibly just "lock" the front diff for the same effect, but you would have to adjust the setup accordingly to get more off-throttle steering since you lose some rotation without the one-way action.
Just thought I'd share some tips and a setup I found over the weekend!
#1512
How do I know if my diffs are too tight?
#1514
Good tip, but its not the stock motor. Its a 6800 Sidewinder.
