-   -   Mini Z steering problem (https://www.rctech.net/forum/micro-mini-scales/1113516-mini-z-steering-problem.html)
Bruno L 06-09-2023 06:53 AM
Hello! Just got the AWD MA020 Mini Z from Kyosho and observed that the turning radius for right turn is way bigger than left turn. So it can barely turn right.
I´ve already aligned wheels to middle and set the transmiter turning knob to maximum. I´ve tried runing on both grip and drift tires, same issue.
So I disassembled all steering parts to see if there´s something wrong but all ok, except little looseness on the swing shafts which I think is quite normal since its all plastic.
Maybe something wrong with the servo? Please support. Thanks!
