Mini pins: How do they work on dirt?
Are these primarily for carpet, or do they work well on dirt too? Always looking for tire options. I wish AE had tire options but I love the quality of the Losi tires. I see the Losi mini-pins available most and I like that you can get just the tire and reuse the rims.
There are no carpet tracks anywhere around here, so it's asphalt and dirt for me. I'm still messing with asphalt tires but have found happiness with the mini-8ight DB tire. It's very controllable on loose dirt.
Tony.
Tony.
Losi mini king pins are a good dirt tire. They're soft so they will wear out fast on asphalt. Tamiya's rally block tire is really good for loose dirt. For running on road you can use any 26mm 1/10 on road tire.
Can you point me to the right rim for the Tamiya rally block tire? I can never find size dimensions for the Tamiya tires and rims and compatability.
This is my current tire inventory, but I also have some LC racing desert tires inbound.
Thanks!
Tony.
Thanks!
Tony.
You can use any 26mm wheel but you can search for a tt02 wheel and you should have it right.
Here are the tires.
https://www.ebay.com/itm/Tamiya-5486...MAAOSwJiJgIXzz
Here are the tires.
