Mini z need a help
Old 02-09-2021, 12:04 AM
Default Mini z need a help
I have an evo mr03 trying to find a way to calm down front making it easier to drive . Can someone explain how to adjust front roll center ??? Mine is very much at stock with green spring front with 30 with glued sidewalk. May be my roll center is too high ?? May be lowering it helps to reduce twitchiness ?? Please help
Totoka is offline
Old 02-12-2021, 02:37 PM
What controller are you using? Maybe try turning down the dual rate.
Make sure you don't accidentally have a Narrow tie rod in a Wide configuration, it will give crazy toe out.
superfly05 is online now
